Battery chain saws
Having suffered another 'stutter to go' - even after it running OK a few weeks back, I know I can stick the carb in an ultrasonic cleaner...along with the one from the hedge trimmer but that necessitates finding everything and so given deadlines I was thinking about simply getting a new one then doing up and selling then old one when I had more time. But then I thought....
I've alrady got a good selection of Milwaukee batteries and tools...so why not get a battery one ? I'm not a lumberjack and the use is sporadic so battery fis ideal but what are they actually like to use ? Is there enough oomph ?
Just had a quick look at the Husqvarna range ( I’ve had a corded electric for 18 years) and it seems their cordless ( they no longer do corded it seems ) are just as expensive as the petrol. I suspect, again no experience, that there is a better chance of fixing/repairing/servicing a petrol than an electric in a few years time.
I went electric because I did not want the weight nor the noise of the petrol. I’ve used a ripping as well as a crosscut chain on mine. Can’t recall the length of the bar at the moment. It has cut trees of no more than about a foot in diameter .
My gardener was showing me his new collection of Stihl battery powered stuff today. The secateur apparently can cut through an inch no trouble. The small hedge trimmer is so light and the short bar ideal for small shrubs and hedges, and he said the same for the short bar chainsaw. So for him he said that although it was expensive to change, they are light, powerful and quiet, with less maintenance and no need to carry fuel in the van making his job less irksome.
I don't have a chainsaw (am married to a hand surgeon!) but friends who have made the move including tree surgeons have all raved about electric - however there does seem to be a split view (in the profession) between the Sithl / Husqavana type level of professional electric kit and what might be seen as the more amateur Bosch / Ryobi etc. kit - where Milwaukee or Makita etc. fit in I don't know... so worth looking at reviews of specific items - but in principle electric can work well
My mate has a DeWalt cordless and it's pretty good though it does seem to eat batteries, no issues for him as he has about a dozen and several other suitable tools.
I have a Stihl petrol combi which is damned heavy and awkward especially with the extension bars fitted, it's too expensive to change but I'd swap for the same in cordless in a heartbeat having had a go with one a few months ago. I don't know about other makes all the pros I know use Stihl.
With garden machinery, infact anything that runs a fuel system open to the atmosphere which means carburettor then E10 fuel is not good, only buy E5 or look for Aspen. E10 seems to destroy the fuel system and I have had to replace several carbs.
Due to enforced serious rethink about plot maintenance we have indulged in a selection of Stihl battery items, we have both the secateurs** , which have made the manual loppers more or less redundant, and they do indeed cut 25mm mature wood with ease; and the small grass/shrub trimmer which is proving more than capable of tackling shrub and hedge trimming up to 6-8 mm thick stems. both items don't even show any significant battery usage between coffee breaks.
So far I can't envision any of their battery chainsaw models not being capable of adequate performance.
The only negative we have experienced is battery working time with the likes of the the small strimmer which is far more thirsty than the two already mentioned using the same small battery, having a couple of spare batteries to hand removes the frustration of just needing a few more minutes working time.
The scarifyer works well but is battery thirsty. The largest of the Battery Hedge trimmers, it's an excellent machine but is no lightweight to handle,
(**scary keep other hand well away from front end)
So my thoughts regarding a chainsaw would be that battery run time would be the only niggle not the performance
My house in rural Virginia was heated in the winter with firewood that I harvested and split for the woodstove. I had three Stihl 028 chainsaws with different bar lengths (13, 16, and 20 inches) for felling, cutting, and trimming trees and routine yard maintenance during the year.
At the time, battery versions didn't exist and any corded electric versions were useless for my purposes. A five-gallon can of fuel and a gallon of bar oil lasted all day, so I can't imagine how many batteries would be needed for the same amount of work.
If I had a need for a chainsaw in my current urban environment, it would be the Stihl MSA 60 C-B. This chainsaw uses the same batteries as the rest of my garden machines. When my 15-year old Viking gas mower makes the journey to mower Valhala, I'll replace it with a Stihl RMA 443 (or the equivalent non-self propelled version) and stay with the same battery family.
I used to have the RLA 240 scarifier because it used the same batteries but it struggled with my yard and went through the AK20 and AK30 batteries quickly. I replaced it with the gas powered RL 540. Fortunately, my local Stihl distributor gave me full credit for the RLA 240.
Many thanks to everyone for the replies. The starting point (somewhat obviously in retrospect) is what battery regime have you already invested in. In my case, it's Milwaukee. If I didn't have that investment then I'd have gone for Stihl.
I'd not thought about the top handle but fortunately the one I've opted for ...40cm bar..has one.
I've used Aspen for years. Still makes no odds as the carb gums up.
I've used mostly 2 stroke chainsaws but have an electric stihl pruning pole saw. The advantages of electric are discussed above. The only things I'd add are to recommend buying the highest capacity battery you can afford as it will make the biggest difference in terms of run time. All depends on what you're cutting of course. I was slabbing large beech and poplar trees and battery wouldn't have worked for me but crosscutting smaller stuff should be fine. One other thing is that apparently electric produces greater torque than similar class petrol machines and it may be instant so although petrol roars, electric saws might be potentially more dangerous.
I agree re the use of Aspen Rog. Most of our kit is Stihl. The hedge cutters are reliable but the chainsaw is always a pig to start after winter. In fact I've got an 18" one in my outdoor kitchen at the moment that splutters girlishly but won't start. Stihl battery tools are excellent - we have that platform too.
My small chainsaw (14" blade) is a Greenworks 40 volt. Battery chainsaws run noticeably slower than petrol, but also stop very quickly when the trigger is released. I get about 35 minutes of continuous cutting out of the 40v battery - mostly cutting up large tree branches into log splitting lengths. Takes at least 2 hours to re-charge the battery, by which time I've got all the logs split and stacked.
I had a break in and they took both my decent. husqvarnas ( walked straight past the budget kit)
I was considering the dewalt battery powered as a replacement for exactly the same reasons as Roger.
In the end cost played a part so I bought two cheap petrol ones for not much more than a dewalt.
Hopefully they will walk past those when they return.
I find it does not go off and my stihl multi, loppers, hedge cutters, blower all work fine with it however long they are left, but 2 stroke chainsaws are temperamental for some reason. I am aware that the stihl butterfly lever is prone to manufacturing errors on their smaller saws so that might be the cause. Still have to strip it down.
I put fuel additive in my petrol and ran my previous Honda mower for 24 years before changing, my Honda ride on is now 13 years old the previous being a similar age when the deck gave up the ghost and my Stihl engine starts every time, first time. never had an issue of note with any of it apart from a Makita chainsaw which has been temperamental since the day I bought it.
I use Stihl, Briggs and Stratton and other makes of additive and buy the cheapest petrol I can get locally 20l at a time.
I guess it depends how long you keep the fuel'
Thats basically the mirror of what I do!
No additive but I use Shell vpower fuel
Everything starts readily no matter how long its left
I looked at fuel additives in the past but once I saw they had an expiry date I changed my mind
I have the Milwaukee 18v 16" saw, (and a few dolmar 7900s, a old really old Stihl 028 and Alpina pro45)
The Milwaukee works well. The newer forge 8 & 12ah batteries make a noticeable difference in run time.
Chainsaw arrived and he's a meaty, man-sized chainsaw! Works extremely well and thinking about getting the 20cm as will probaby get more use out of that as a trimmer.
Wotcha got then Rog?
And does the fact that it arrived mean your delivery driver problems are resolved?
I went for the 40cm Milwaukee.
Delivery drivers are a movable feast - no pun intended. Some will drive down....the local Yodel guy does that...top man. Kelly - our EVRI driver is also good. DPD are the worst. None of the DPD drivers like the rural round that we're on for the very good reason that they can't make any money. Distances between properties far too great means that they can only deliver fewer parcels in a day and since they are paid per delivery....
Where we can - Amazon for instance - we pre-empt issues by filling in the detailed box telling them exactly where to leave it. Works reasonably well.
I should add that went to use the petrol hedge trimmer yesterday. Ran OK last year. I clearly forgot to run it dry as the remaining Aspen had turned blue. Tipped it out. Replaced with fresh. Would it start? Nope. Took down the long-reach hedge trimmer which I was doubtful about as it didn't run very well last year...clagged carburettor again. Still NBG. So that's both hedge trimmers out of action. The access track to us looks more and more like the Amazon jungle every day. New hedge trimmer arrives tomorrow - petrol sadly as the Milwaukee hedge trimmer is very, very spendy..
One day, when (a) I have found the ultrasonic gizmo (b) found the cleaning stuff for it (c) have somewhere to dismantle the other two and (d) time to do the dismantling.....in other words probably when Hell freezes over as each day reveals yet more defects in the House of Horror.
Should also add that LOML has her own Garden of Grisliness. Note to anyone looking at buying a 'new' house, check out the grounds and if they are pretty much all grass that has been mown to within a mm of its life - and you're into gardening - then walk away. Because that close-cut grass is hiding all those perennial, tap-rooted weeds that are in the entire area. DAMHIKT
I wouldn't base my decision about buying a house based on the condition of the lawn (garden to some). If that was the case, I wouldn't have bought the house I live in now.
The yard (garden) was a construction zone and most of the green was weeds. Mowing was a challenge because of the rocks and construction debris. Fortunately, I planned on a complete renovation, which included killing off everything remotely green and removing a one cubic meter mountain of concrete that was the dump station for the concrete trucks when my house was built. I also brought in about ten tons fill dirt to backfill the new retaining walls needed to level the lawn (garden) and five tons of screened top soil as the final layer.
Years later, I had an infestation of quackgrass (goes by other names all of which are associated with the spawn of evil). The only options available were to embrace the spawn and watch it rapidly take over my lawn, apply a non-selective herbicide and hope it worked, or the nuclear option of removing the soil in the affected area to a depth of 30 centimeters to ensure removal of the rhizomes. I went with the nuclear option and removed an area of about 60 square meters. Six years later have been spawn free.
In the case of a "new" house with a quackgrass infestation and in need of a complete renovation, I would likely go with repeated applications over several months with a non-selective herbicide. Once satisfied the spawn was gone, I would rebuild the lawn.
I wouldn't base my decision about buying a house based on the condition of the lawn (garden to some). If that was the case, I wouldn't have bought the house I live in now.............................
You should have seen mine. :ROFLMAO:
The house had been empty for 8 months after a fire and the previous owners never cut the grass, at that time about 1/3d acre, they just put a match to it once a year. When we moved in the kids were very young and the grass was a good 3ft high, they loved playing and hiding in it and cried when I got a local farmer with his tractor to cut it down We had two drive entrances, one properly tarmacced and the other just a gap in the hedge where the alcoholic owner drove his Granada through, regularly. Personally I don't care one jot how many weeds are in the grass as long as it's green and useable, 3 hours cutting the damn stuff, every 5 days at the minute is enough for me to think about.
The house was a disaster but I knew that, saw the potential though my wife didn't and I got it for a very good price. That was 39 years ago and we're still here.
The thing is, Mike, that since the ‘grass’ had been mowed to pretty much ground level there were no clues as to the true state
I've got Stihl long bar hedge trimmer and the strimmer, both use the same battery, both excellent machines. Not cheap but excellent quality.
