Halo Jones
Hi All,
I've started to think about the next stage of house refurbishment which involves, among other things, installing a wood burner in the corner of a room. Scottish Building regs state that "walls abutting the hearth should be at least 75mm thick non-combustible material at least 1.2 m high or 300 mm above the top of the stove."
The obvious thing is to build a single brick wall to the required height but can I build this straight onto the existing floor (ie joists and floorboards)? This doesn't feel right but is it ok?!
Any other ideas on how to achieve the required non-combustible thickness?
Cheers,
H.
Cheers,
H.
