Alder
I regularly empty a de humidifier on someones behalf and I am surprised how clear and clean ithe content looks, are there any hidden impurities ,
Thank you,
Russell
Thank you,
Russell
Woodster":vv0sgcwr said:There are several types of dehumidifiers and I read somewhere the waste water from one type could contain tiny amounts of heavy metals.
Dehumidifier water is ideal for feeding to venus fly traps and other carnivorous plants, as it has none of the calcium content or other additives in tap water, which they don't like.Woodster":12xscdh2 said:I wouldn’t even water the plants with the output from ours. :lol:
Woodster":1979qqt1 said:Our tap water is quite hard (TDS about 275) so I collect rainwater (TDS about 50) for my Aquarium. I do sometimes though do top ups with a mix of tap and Zero* water. We don’t actually drink any Zero water as it has literally nothing in it. It was bought as a “just in case” purchase at the start of the first lockdown. Looking at the mould that needs to be removed from our dehumidifier reservoir from time to time the best place for the water is down the drain, I wouldn’t even use it in an Iron.
* https://zerowater.co.uk/
Another urban myth I fancy. We’ve been drinking and cooking with softened water for over three decades and we’re still here to tell the tale :lol: and we’re actually on our second Kinetico softener, having worn out the first one. The reason we started to use softened water originally was that SWIMBO had an unpleasant skin condition which has been helped enormously by the absence of hard, chalky water. In over thirty years, I’ve never had to de-scale a kettle or shower head, a wet shave is a pleasure rather than something to be endured and my ‘builders’ in the morning never has a layer of scum floating on the top.Woodster":30uxem9w said:Some also said it was better to drink unsoftened water as well. Apparently at least one tap is normally left on the domestic supply for this. One guy replied that the company that installed his unit hadn’t done this so following the conversation he had a pipe that bypassed his softener for cooking and drinking purposes.
Most softeners work by (long story short) replacing the calcium ions with sodium ones. In most cases the added sodium has negligible effect on drinkability, but depending on the exact method the softener uses and how hard your water is to begin with, it's possible for the output to exceed the legal limit on sodium in a drinkable water supply. A decent installer should test for this and, if it's the case, fit a bypass tap and tell you to use it for drinking/cooking.Woodster":16t21djr said:There was a discussion on an aquarium forum some time ago and folks were saying not to use the water from softeners for a planted aquariums. I can’t remember why. Some also said it was better to drink unsoftened water as well. Apparently at least one tap is normally left on the domestic supply for this.
spb":2ik46wj7 said:Most softeners work by (long story short) replacing the calcium ions with sodium ones. In most cases the added sodium has negligible effect on drinkability, but depending on the exact method the softener uses and how hard your water is to begin with, it's possible for the output to exceed the legal limit on sodium in a drinkable water supply. A decent installer should test for this and, if it's the case, fit a bypass tap and tell you to use it for drinking/cooking.
I can imagine some types of aquarium fish being more sensitive than humans, seeing how they have to breathe it as well as drink it. The same principle will apply about depending on the initial hardness and exact method, plus also the particular species of fish you have, so in that situation the conservative advice will always be don't do it unless you know it's going to be OK.
Woodbloke":2ik46wj7 said:We’ve been drinking and cooking with softened water for over three decades and we’re still here to tell the tale :lol:
Woodster":2un0ppj3 said:Just because doing something potentially unhealthy doesn’t kill you straight away doesn’t mean it’s a good idea. Some things take a several decades to become apparent.![]()
spb":1c71ywwo said:Most softeners work by (long story short) replacing the calcium ions with sodium ones. In most cases the added sodium has negligible effect on drinkability, but depending on the exact method the softener uses and how hard your water is to begin with, it's possible for the output to exceed the legal limit on sodium in a drinkable water supply. A decent installer should test for this and, if it's the case, fit a bypass tap and tell you to use it for drinking/cooking.Woodster":1c71ywwo said:There was a discussion on an aquarium forum some time ago and folks were saying not to use the water from softeners for a planted aquariums. I can’t remember why. Some also said it was better to drink unsoftened water as well. Apparently at least one tap is normally left on the domestic supply for this.
