Rezi
I moved home earlier this year and my new house has very thick brick walls (500mm) but no insluation. The ceilings are also quite substantially built. Bricks here are the type with a lot of voids.
I had hoped, through the warm part of the year, that the thick walls would not require any insulation due to the thickness but I've noticed that as the temps have dropped the central heating has struggled to keep the house above 20C.
There are other mitigating factors relating to the central heating but I'd like to know whether thicker brick walls are any better or worse than standard brick construction at retaining warmth.
Also, has anyone tried using a thermal imaging/heat sensing app and are they any good?
Steve
Steve
