TomTrees
- Joined
- Aug 19, 2014
- Messages
- 390
- Reaction score
- 108
Hello folks
Seems the other place where I started this post is having some hickups! :eusa-violin:
Here is a lump of metal I found on the road, guessing it's a part from a lorry, as there was a lump of rubber bonded to it.
Some scraping of the centre out ala Bill Carter
Checking the table for squareness using a method I'm told is referred to as tramming...
And some more inspecting and getting things setup
Not sure if this part will be used, as the hole became oversized for some reason.
One thing for sure is this stuff is hard!
It has eaten the grinder wheels when spun on a shaft like a dressing tool, so
depending on if I can grind the hard stuff away, and the hole is good enough when parted off,
it might or might not be used.
I've got some derlin to use for the job, so this part is not important.
Looking at some other videos since, it seems that case hardened steel is a challenge for the best of lathes.
This piece was absolutely eating various steels from files and the ends of cheapie HSS drill bits,
so am really surprised that this glass cutting bit has been working so well.
Not done any messing about with this bit yet, so things could likely be improved.
Inspired by the Turnado lathe tool, which is pretty impressive BTW,
but rather than make up a load of stuff, I thought it would be interesting to try doing things on the fly as it were.
This should work half right on mild steel with some decent HSS drill shafts, made a tool holder for that, but as said the bits got eaten in a few seconds, without a hint of a chip.
There is some folks doing so on youtube, so it's gotta work.
Here is a prior attempt, and a view of what I mean
And here is today's attempt, using a glass cutting bit,which I believe are carbide.
Hot little chips are coming off of it, seems it might be worth persevering to get down to the soft stuff.
One video mentioned that case hardening can be as much as 5 or 6mm, so salvaged metals are often more trouble than their worth.
Not sure If I'll keep at this, might do an update if I start getting some real chips.
If the tool gets obliterated, I might rig up some regular pipe as I'm told it's softish,
and see how the previous idea fairs.
Found some good videos on making tooling from HSS blanks on the tube...
mainly from "This old Tony" and "Abom79", so it would be interesting to see how things go for again.
I'll try and report back if I get some nice chips either way.
Seems like its worth the trouble to affix a track to the underside of the plate for easy alignment.
Only bodging things yet, and working on making things a wee bit more usable,
but trying not to go overboard as I've not got a chuck yet,
so kinda resisting doing work that might be pointless, and besides...
I find it interesting to see how much things can be stripped back.
Might even consider getting some carbide inserts locally if I nearly get there with this lump of case hardened steel.
I made a wee video which some might find amusing
https://www.youtube.com/watch?v=iFYU2do ... e=youtu.be
Thanks for looking
Tom
Thanks for looking
Tom
