I mentioned that I lowered the dining room beam a few inches and cleared an obstruction above it before raising it again. Well, it now sits down onto the bracket perfectly:
Then I turned my attention to the other end of the room. First problem.......a modern ceiling in the way:
Note the softwood under the bridging joist, with the 2 threaded rods. For those who've forgotten, this is what is holding the beam up in the air at the moment, and with it, the floor & ceiling. Anyway, I hauled the ceiling down (I found a hoe from the garden shed to be the best tool for the job!):
Here is the problematic joint, still painted with the original limewash:
After cutting out:
I made up the beam as before, but left a little tolerance this time around the central saddle. learn from experience, I say:
This time I cut the right joist off!!! Here is the end bracket sitting out of the way where the joist end used to be, ready to slide into position in due course:
Ready to lift:
Going up:
The heights worked out less well than last time with respect to the length of the hoist chain, so I put up a scaffold to take the weight whilst I adjust the winch for a second go, Here you can see the RH end of the joist sitting in its bracket:
It's up. Last little bit by acrow prop. Perfectly onto all the brackets first time:
Here is the left hand bracket sliding into place along the girding beam:
The acrow was then removed, and some minor tweaks performed to the alignment of the beam with the fine adjusting tool:
The middle and RH joints went really well:
The left hand end bracket isn't perfect. Maybe the girding beam isn't quite straight in this location:
