Well now..that was a lesson in building for sure. Thank you for that. The explanation that you gave was just what a novice needed. It is great fun to learn what was/is. I sincerely appreciate that. As you would say...cheers...bill
Mike, to quote another Dutchman, Rob, You sir are a magician. :text-bravo: :text-bravo:
And an inspiration to this Boertjie! (14th generation dutchman too)
I've sworn an oath on my dead cat's liver that I'll not show my wife this thread, else she may import you for some tasks around the house.
But alas, my son who now lives on you fair isle, has, and he expects his old man to do it the 'Mike-way'!
So I've committed to doing things the 'Mike-way' from now on.
Plan, Plan, Plan. Get the right materials, and do it right first time!
Your info on using lime render and the mix is most informative.
You would know about the old Cape Dutch buildings down here in the Western Cape. They were built with sun dried adobe type earthen bricks, and the 'mortar' was also a mud/clay/chopped straw mix, and where straw was missing, cow dung, or whatever was to hand, even horse dung, etc.
The walls were plastered with the same mix, and once dried out, a lime wash was made of slaked lime, water and animal fat to an almost slurry consistency. The water reacted with the slaked lime and created heat, which melted the fat, and the melted fat coagulated with the lime particles. This slurry was brushed on with a rough brush, and the fat/lime 'slurry' was the waterproofing on the oustide walls, that prevented moisture from getting in. This white washing had to be done quite regularly to keep the walls waterproof, and in old travel documents sometimes mention is made that dwelling hasn't been white washed, and signs of decay are visible, with parts of the walls in ruins...
Sea shells from mussels, abalone, and other shellfish was gathered from the beaches, and burnt in kilns not too far from the beaches, and then transported by ox-wagon to wherever it was needed.
We can be thankful for living in the 21st Century, but still need to know how the craftsmen of old did what they did, and why they did it that way!
Hey Thys. Good to hear from you again. Hope you are well.
Great post! Yes, I love the old Cape adobe/ clay lump/ cob buildings*, and you're dead right about the limewash, too. There are cob buildings in Devon whose walls are probably 4 inches thicker than when they were built because of the centuries of limewash inside and out.
* All using much the same materials (often just mud/ straw/ dung scraped off the farmyard), but slightly differing techniques. Whereas your ancestors in the Cape made sun-dried bricks from it, here it was often just pounded into formwork in situ, allowed to harden a bit, then the planks raised up and the next layer added.
Thanks Bill.
I've done nothing but draw since then, and I'll be drawing for another few weeks at least. Once I get this backlog of work out of the way I'll be plastering the hall and dining room, then building the 2 front doors. It's these I've been looking forward to the most for some while now.
Having withdrawal symptoms for a few weeks now from not seeing more of the masterful craftsmanship.
Mike, I hope you get some well earned rest over the festive season, that your new roof will be tested by some good snow while sitting in one of the best planned and crafted houses I have seen in many years. :eusa-clap:
While you are having the cold season I am venturing out camping in our semi-desert Karoo to think about that ancient wooden house in the Northern hemisphere that has been given a new life for many (hundreds) of years to come!
Best wishes from SA!
Carel.
Whereabouts in the Karoo, Carel? I spent 6 months in Graaff Reinet, so I know the Karoo very well.
As a coincidence, I am hoping to start work again on the house tomorrow. I'll be doing some wiring and then plastering in the hall and dining room, then doing the stonework on the floor through the hall. The downstairs window cills are nearly ready for fitting, too.
Oh, and it's all covered in snow at the moment. This is our first snowfall in 4 years in the area.
Thanks Mike, next summer you can focus on your barbecue place!
Yes Graaf Reinett has beautiful architecture!
See picture for coordinates where we will be camping - (and simmering at 45 C some days!)
Regards.
Carel.
Ah, right. I've not been there. That's way to the west of the area I know well.
Enjoy it.......camping in the velt feels like a nice idea as I sit looking at the melting snow.
I've been drawing, and I've had the flu. Flu is bad: don't get it.
I have managed a little work on the house. I wanted to get the dining room done so that we can empty the contents of our hired shipping container into that room, and get rid of the container. We also wanted the hall done such that we could walk through the house on a finished floor. So, here are a couple of almost "before" photos, which show the plasterboard going up in the dining room and hall. Unfortunately, I had the camera set to "Macro", so they're out of focus:
The plinth is plasterboard stuck double-thickness to the blocks, and then plastered with a rough undercoat plaster to mimic the typical rendered plinth look of old cottages:
It's quite a pain taping everything up. It was even more a pain when I used some old plaster accidentally, and it went off way too quickly.
After doing the plinth of the dining room and hall, I brought the stone flooring through the hall. I had to temporarily prop the stairs up out of the way to run the stone underneath:
The last photo shows a "well" around the temporary front door, simply because I don't want to be re-hanging this door an inch up just for the few weeks until it is replaced by the permanent door.
Focus moved to upstairs above the dining room ceiling for a while. This was so that nailing floorboards down happened before the ceiling got plastered, avoiding the danger of disturbing the plaster on what are pretty thin joists. So, here is the upstairs before work started, with a temporary board over a small area of joists:
This is a problem. The plumber had previously hacked out a big notch for the hot and cold supply pipes for the bathroom, through a narrow joist:
I decided to "sister" this joist:
......and the pipes will be re-routed later. Here is the progression of the floor:
Note the projecting bridging joist has been cut to length, and note the step. Here is the excess bridging joist in situ from below:
This is the tenon on the end of one of the joists, (and note the tapered peg I pulled out via the screw in the end):
This is one of the classic joints of English oak framing. The long projecting tenon is always bang in the middle of the depth of the bridging joist, on the "line of neutrality" (ie neither in tension nor compression. This means that the bridging joist is hardly weakened at all. However, to prevent twisting of the intermediate joists, the tenon is haunched. This removes as little timber as possible from the bridging joist, but still retains the full depth of the intermediate joists such that they can't twist. When I cut the end of the bridging joist away I had to clamp a piece of scrap to it to prevent it falling:
I could then build the floor up:
The chipboard forms the landing floor, and the old oak boards are going to be in the bathroom (and bedroom). Having done all that I could proceed with overboarding the dining room ceiling, and then plastering:
Another day for the plaster to dry and that room is ready for decorating.
Yeah, there's quite a bit left to do. The dining room will be finished with a coat of paint. The hall is all but finished, with just a bit of work on the ceiling small amounts of plastering, and then decorating. At that point the electrickery can be connected in the old part of the house. The downstairs loo needs a complete job, but should only take 3 or 4 days. There is also the two front doors to do. The lounge needs some plasterboard on the ceiling (once the upstairs central heating pipes have been extended into the old part of the house), and then plastering and decorating. A couple of days work.
That leaves the biggest area of work: the bathroom and 4th bedroom, upstairs in the old part of the house. Floor, walls, ceilings, plumbing, plastering, fitting out.......lots to do. And finally a new staircase to make. One day I'll make internal doors, too.
Add it all up and there is probably 2 or 3 months of work left to do internally, but I am simply not going to get 2 or 3 solid months of work on it this year. I have too much drawing work to do, and we have a wedding to be ready for in July, so everything is going to happen in fits and starts.
fiveeyes":3ignfrrk said:
Plastering..back breaking work! I am glad that I am not good at it, else someone would ask for my help. :o Do hope that you are feeling better. Flu has got the whole U.S. sick, it seems. BTW..Happy New Year
bill
Yeah, I can't say I enjoy plastering, particularly ceilings. However, it isn't all that difficult once you get into it. As I am finishing areas piece-meal, I don't have the option of getting a plasterer in to do a bit here and a bit there, so I am stuck doing it myself. I bought myself a nice new float which has helped somewhat.
This flu isn't pleasant. We both fell ill on Boxing day, and I'm still not right. By lunchtime I need a siesta most days, and by 9 ish I'm asleep in front of the TV, and still with almost no appetite. Don't get it if you can help it.
Sorry about the flu - did you have the jab, not that it gives complete immunity?
I suppose locking yourselves away in isolation is the only way to prevent it.
My wife and I both caught a very nasty cold over Christmas and New Year, probably picked up from our Grandkids who were ill a week or two earlier.
I always worry when I go to our doctors for our repeat prescriptions when walking through the waiting room, wondering if I’ll pick some bug up.
My Consultant says siestas are beneficial but only for 30mins, longer than that you fall into a deeper sleep which makes waking up without feeling drowsy more difficult.
No, we didn't have the jab. Depending on the flu kicking around next year we might well have a jab.
The afternoon nap thing is out of my control. I fall asleep in my chair in front of the computer if I don't go to bed. But you're right........10 or 15 minutes is all you need to get through the afternoon refreshed.
The stone looks great, where is from? We are doing the same in our hall once I finish the bathroom.
Thanks Mike, I'll keep my eye on that, they have some nice looking stone.
Mike G":n2p9x5zx said:
..... I bought myself a nice new float which has helped somewhat.
You'll be disappointed, I think. Unless you're going to prep it properly before using it.
To be fair, I bought it some months ago, and did a bit of work on it before using it to help float up the lime render. The extra length, and the flatness compared to my really old £1-bargain-bin previous float made the ceilings so much easier. Unfortunately, it was rather too large for most of the wall panels, so it was back to the old one for those.
Mike G":3pmo8m1f said:
.... and the flatness ....
That's the thing. Having been working in close contact with excellent plasterers these past few months I now realise that they prefer a 'worked' piece of kit that has curves on it. That way you don't dig in and leave tramlines. They will work a new one to remove the flatness at the edges before using it in anger.
I meant the flatness (or lack thereof) of the face. I filed the edges and the corners before I started using it so they are slightly curved, but having a relatively flat face compared with my old trowel helps quite a lot. What helps most, though, is having the extra size.
This is a small but very significant step for us. A major transformation of the feel of the site from a building site towards being a normal house:
The land behind where the container stood is the site of a proposed new garage, for which I haven't even yet applied for permission. There is a somewhat overgrown hardcore pile where the garage will go:
This is the first time I've been able to photograph the entirety of the southern elevation.
Brilliant that he didn't drop it? Yep.......couldn't agree more! :)
Halo Jones":59slwwsr said:
It must feel like quite a milestone :eusa-clap:
Your workshop looks quite sizeable in that last photo!
If gives a good sense of scale of everything. Lovely to free up some space and a view too.
I expect to see the container being converted into a miniature marvel of sorts on "George Clarke's Amazing Spaces" in the not too distant future.
There's a bit of distortion involved in that last photo. My workshop is some 30 metres further away than the house, and quite a deal smaller.
PHEW!
I have just finished reading the whole of this post over the last few days - what a saga! (Old Yorkshire word for pudding).
An absolutely incredible achievement, along with having more body parts fixed than me, along the way!
I sure have learned loads about different construction methods and how little I know.
If you want to see big timber construction look at Pure Living For Life on YouTube. Lots of crap but some good bits.
It did, over several days, but I was a Technical Author so well used to reading lots and extracting the relevant bits.
The secret is wife mot around and plenty of whisky!
Seriously, learned loads from this post alone, plus lots about useful materials
Keep up the good work!
