Cabinetman
- Joined
- Oct 11, 2020
- Messages
- 5,718
- Reaction score
- 1,397
- Location
- Lincolnshire Wolds + Massachusetts
- Name
- Ian
You might remember that I have treated myself to this new machine. I haven’t had much time to play with it really but it was fairly quickly apparent that something had to be sorted with the Fence arrangement when using the T/saw.
The fence as supplied is about 4 feet long, heavy, cumbersome and in my view pretty unusable ( it’s a complaint from most reviews) to use it as a short fence as the HSE and I say is the safe way to do things, it has to be brought back towards the user this brings it so far back as to be completely in the users way.
Also it is the same fence used on the planer, but the aluminium extrusion has to be taken off and turned around to enable you to use it. Sometimes it is handy to move between sawing and planing repeatedly, this is unworkable.
So something had to be done!
The machine
The fence sits on a hefty machined lump of Aluminium and so I replicated the lump in Ash with a ringbolt as the tightening screw, this has a piece of Formica inserted to prevent the end of the ringbolt gouging the bar on the machine. The thumbscrews are temporary till I can get something better.
The fence itself is a piece of 2 1/2” x 1 1/4” Ash with a thin piece of an unknown hardwood on it’s face, this covers the heads of the Coachbolts and allows the fence to slide in and out depending on the operation.
Sorry I haven’t quite got the hang of adding photos yet.
The fence works—perfectly!!
The machine
