Motor 750watt min 4pole 1400 rpm
Hudson Carpentry
Nottingham
I am in need of a motor that is min 750watt, 4pole and 1400rpm. Single or three phase.
Ideally Face mounted with a 19mm spindle.
Thank you
Sent from my SM-N910F using Tapatalk
Thank you
I have two possible candidates. both 4pole, 3 phase 1hp
no1 is face mount. (ie e bolt holes inside the diameter of the motor)
The gear is cut into the shaft but quite easy to machine up a sleeve to push fit over the teeth and pin to give a 19mm shaft.
No 2 is a flange mount (ie bolt holes outside the diameter of the motor)
This spur gear looks like it will pull off, the pin has already been removed. Again a simple turning job to give you a 19mm shaft.
These photos were taken for someone else who never turned up to collect. I can provide more info if you are genuinely interested.
Both are good runners, no known faults and they came from a trusted source.
I took them in PX payment for a job and I'd be looking for £25 each. I can pack them for your courier to collect from SO515RS.
Hope this helps
Pictures dont show up on tapatalk, but quite a lot don't. Was fine on the PC earlier.
Non working but I am on tapatalk and I have noticed a few posts have broken images on here. Links are not working either. Will login via a pc later and look.
I can see you photos fine on Tapatalk.
All this hurts as I swapped my 3phase Meddings motor for a single phase one!! [emoji35]
