Stuck Spindle block
riclepp
Halstead
Hi All
Hoping for some advice. I have a sip spindle moulder, and I have the cutter block stuck on the spindle itself and it won't budge. I have used plus gas and a hub puller to no avail. I am going to make a moveable triangle to the hub puller has something to bit on as the block it rounded and the puller slips off.
Has anyone had this issue and if so what did you do to free the block.
Many thanks
Richard
Give it some penetrating oil and let it soak for a day. Is it rusty? Is the cutter on a threaded part of the shaft? Do your best not to bend the spindle.
Oh, and WD-40 is not penetrating oil. You can make your own with a 50-50 mix of acetone and automatic transmission fluid.
Kirk
kirkpoore1":390of0ku said:
........You can make your own with a 50-50 mix of acetone and automatic transmission fluid........
Don't get that on your skin!!
Kirk
Hi Kirk
I don't think it is rusty as I can't see any out the spindle Itself. I am hoping that it is only resin from the wood that is binding it. I have been using plus gas, which I have been informed is good stuff. I don't really what to hit the spindle in case it messing the rise and fall mechanism. So I am guessing I should heat up the block a little.
9fingers":1t6guk64 said:
I would do whatever you need to to secure the puller on and apply tension.
It might budge with moderate mallet blows or if not, apply heat and increasing tension.
Good luck
Hi Bob
It's an ally block, anything I need to be aware of in regards to heating ally, as I have never done that ever.
Richard
I'd have thought your best bet would be a bearing removal tool Richard, the hooks would go under the block & the bolt onto the spindle to pull it up.
Good luck
Hi Bob
Richard
No problem heating aluminium with "normal" blow torches. The coefficient of expansion of aluminium is about twice that of steel and it should release it nicely. Try to heat the block rather than the spindle anyway.
@Kirk Plus Gas is a well reputed penetrating fluid in UK I don't know if you have it on your side of the pond.
I've heard of the efficacy of the acetone/ATF mix but never needed to try it.
+1 regarding WD40. Good for driving off water but very average at most other jobs. It makes a reasonable job getting a good finish when machining aluminium if there is no paraffin (kerosene) to hand.
Good luck
Hi Bob
Richard
Thanks Bob, will have a go this weekend.
Regards
Richard
Could you raise the spindle up to its highest extent which hopefully should raise the bottom of the block above the top of the spindle moulder bed. Then put some steel or thick wood underneath the block across the opening so it sits on top of the bed. Then lower the spindle and hope it frees up the block with a little judicious tapping on top of the spindle ?
