Hudson Carpentry
Ok. I recommended this router for under table use to a friend. They stuck a 20mm diameter cutter in it, raised it to cut 20mm in one pass and left it there. Now he puts 115mm square redwood through it to cut a mortise. So in one pass he cuts a slot 20mm deep, 20mm wide and 120mm long. Quite often the wood is forced through faster than it should.
In my mind this is abusive. Cutting with a 20mm cutter to a depth of 20mm should be done is a few passes. Am I being over paranoid?
On an other note he is on his 2nd triton now. The first went just before Xmas only about 5 months old. The speed kept fluctuating, sparks seen through the case & slight burning smell.
He brought a new one and now the same has happened but with the added symptom of that you have to knock the cutter to start it after you give it power.
My first thought was speed controller due to over current when over loaded which caused the speed fluctuations.
I thought about bypassing the speed controller as the unit will only ever do this one job and use the same size cutter. Couldn't find the starting capacitor.
He has been meaning to send the first on back under warranty but I doubt he will now. can I bypass the speed controller without a starting cap? Also is the reason for these units going bad due to overloading or should this unit be capable of cutting 20x20mm in one pass?
Thank you in advance.
