StevieB
So I have an interesting little project coming up shortly - laying approx 20m2 of reclaimed teak parquet flooring in our dining room. Photos to follow, but first I have a question! I understand about leaving an expansion gap for the parquet itself and as removing the skirting was not an option I am resigned to fudging this. 12-15mm seems to be the recommended gap and I have a solution for this that while not perfect will suffice I hope.
My question relates to the ply sub-floor. Wooden floorboards with a void underneath and I am putting down 12mm ply as a base for the parquet - do I need to leave an expansion gap between the ply sheets themselves and between the ply sheets and the walls/skirting? I would prefer not to for logistical reasons, but if that is the recommendation how big a gap is necessary? Ply is bog standard spruce (not quite shuttering ply but not hardwood faced either - it is going to be fully covered so didn't see the need at twice the price) and will be screwed into wooden floorboards at very regular intervals but not glued.
Assuming this goes well, I have enough reclaimed flooring to do our hallway as well (approx 15m x 2m) so want to get it right if I can. It has been sitting on the back drive for over a year however, so some indoor acclimatisation also likely to be required - any indication of how long this will need to be indoors before laying? It has been covered with a tarp/groundsheet but I doubt this is fully waterproof.
Steve
Steve
